aaronalpha3
APPROXIMATE PURCHASE DATE: Within this week/month
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: audio editing, gaming, surfing the web, watching movies
PARTS NOT REQUIRED: case (AZZA CSAZ-910 ATX Helios 910... on sale for $45 after rebate), keyboard, mouse, monitor, speakers, Windows 7, surge protector
PREFERRED WEBSITE(S) FOR PARTS: Newegg
PARTS PREFERENCES: AMD Phenom II X4 955 BE, 4GB (2GB X 2GB) DDR3 1600 RAM, 500 GB hard drive
OVERCLOCKING: No
SLI/CROSSFIRE: No
MONITOR RESOLUTION: 1600x900 (for now)
ADDITIONAL COMMENTS:
These are some products I've been looking into, what do you all think and if there is something better or a deal/combo I'd appreciate the advice:
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor - Retail
http
/www.newegg.com/Product/Product.aspx?Item=N82E16819103674
$160.99
COMBO DEAL:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
XFX HD-485X-ZDFC Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
http
/www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.343070
$234.98
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http
/www.newegg.com/Product/Product.aspx?Item=N82E16822148395
$54.99
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD/CD Rewritable Drive - OEM
http
/www.newegg.com/Product/Product.aspx?Item=N82E16827118030
$23.99
NZXT Sentry-2 5.25" Touch Screen fan controller - Retail
http
/www.newegg.com/Product/Product.aspx?Item=N82E16811992005&cm_re=fan_controller-_-11-992-005-_-Product
$29.99
GIGABYTE GA-790XTA-UD4 AM3 AMD 790X SATA 6Gb/s USB 3.0 ATX AMD Motherboard - Retail
http
/www.newegg.com/Product/Product.aspx?Item=N82E16813128416&Tpk=Gigabyte%20GA-790XTA-UD4
$139.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM - Retail
http
/www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=ripjaws_1600_cas_7_4_gb-_-20-231-303-_-Product
$114.99
What would you guys change and could you check to see if everything is compatible?
I want to be around 800 or less
I would like this computer to play new games at full speed but also be relatively quiet (fan controller should help)
Also, I have been doing a lot of research but keep in mind this is my 1st build
Thanks for help in advance!
OVERCLOCKING: No
SLI/CROSSFIRE: No
http
$160.99
COMBO DEAL:
http
$234.98
http
$54.99
http
$23.99
http
$29.99
http
$139.99
http
$114.99
