I recently purchased and built my first system, and was wondering if I could get some help with configuring memory timings in the bios. I've updated the bios to the latest revision, because the original did not support dual channel with DDR2 1066 memory.
My board: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128384&Tpk=GA-MA790GP-UD4H
My memory: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820227362&Tpk=OCZ2G10664GK
The following is a screen shot of the memory timings bios page:
So the obvious change is to manually set CAS/TRCD/TRP/TRAS timings because auto set it to 5-8-8-24, where-as the memory specs indicate that it is 5-6-6-18.
But what about the rest, namely Command Timing which has a -- on auto but I have to manually set it?
Also, what is SPD?
Also, what is SPD?
