New system - need advice for OC cooling
barthautala
44
Water block or Heat Pipe tower with 120mm fan?
Has anyone seen anything for 1 vs the other?
It almost seem like you could do a hybrid? For instance mount the cooling tower and run water tube through the heat sink on the tower to help extract the heat from the tower?
phreejak
1,376
It has been done actually. Altough, at the time, the product eludes me. In fact, it has been done for a standard water block (as you had suggested) and for a thermoelectric water block as well.
Here's something of a review along the lines you spoke of.
Here
This link may or may not still be up
barthautala
44
Nice Linky..............thanks alot!
I was thinking of then having just 2 loops.......One for my CPU and one for GPU.........
Anything else I should water?
Here is a noob question.............is leaking ever a problem? And if something did leak would that be pretty much it for your components?
phreejak
1,376
You don't need two loops, just one loop with two rads like how I've set mine up
Reservoir - pump - CPU - rad - GPU - Rad - Back to reservoir
In this configuration, neither major component need suffer from the heat of it's own generation AND heat from the other component without the benefit of the rad cooling the liquid before it reaches the other waterblock.
For 5 years now I have been using PC ICE, it's a bit pricey ($19.95/bottle and I use 1 1/2 bottle per filling) but it is a lubricant (for the pump), anti algaecide and it is non conductive. I can attest to it's truthfulness as my cooling loops have sprunk a leak or two and I have accidently spilled the coolant on active (powered) parts and nothing has happened.
Can't put a price on peace of mind.
I don't really advocate cooling other parts as the additional blocks only really serve to play havoc on the flowrate of a cooling loop. I would only consider liquid cooling the northbridge IF you do some really major o'clocking of your CPU/GPU. The northbridge coordinates activity between the CPU and the various PCI lanes (PCI, PCI-E, etc.) AND it also coordinates activity between the CPU, system cache (except on AMD machines) and the system memory. So, again, if you do some major o'clocking of those areas then, perhaps, you might consider cooling the NB. But, a good HSF can do a good job here.
Have you already decided on a GPU waterblock?
