Question New System wont post, at a loss, any help appreciated - A2 Error
jacksyee
35
Hi,
I had a CPU failure so bought a new Mobo and CPU and reassembled my rig.
Yesterday evening I could get to BIOS but could not install Windows. How I wish I was there now. Instead, I am now getting error A2.
Sequence of events:
  1. Can get to BIOS, couldn't install windows from thumb drive (no boot media recognized)
  2. This morning, woke up and tried again. Was getting error B6
  3. Re-flashed BIOS (1401), was getting error A2 (VGA light and Boot light on), removed and reseated GPU now no VGA Light but error A2 still
  4. Reset CMOS
I have removed the m2 Drive. No other drives installed
I have removed all but one stick of memory, placed in the A1 memory slot.
Baffled
Corsair 760t Graphite Case
Intel® Core™ i9-9600KF CPU
Corsair Dominator Platinum 64GB DDR4 @ 3200 MHZ 4x16
ASUS Maximus Xi Hero Wi Fi
Samsung 960 Pro 1TB M.2
EVGA SuperNOVA 1200 P2
Windows 10
2xNvidia Titan X Pascal 12GB
use the USB flashback feature to install the latest BIOS to the motherboard
Before running the USB BIOS Flashback tool, please rename the BIOS file (M11HW.CAP) using BIOSRenamer.
install on RAM into slot A2
which CPU failure did you have exactly? Might be a power supply problem
only use one Titan X
your computer will not boot without a GPU installed, the motherboard ports are disabled because your 9600KF doesn´t provide an integrated graphics chip.
Q-Code "A2" means IDE detect which is similar to the boot LED
jacksyee
35
Thanks for the post:
Done
Does this mean put the RAM in A2 rather than A1 - ok done
Not sure exactly, I had it tested and they said it was dead
Ok, they are joined by a waterblock terminal - can I just not power one or do I need to disassemble the loop?
Ok I changed the DIMM to A2 and the VGA light went off. It’s now just A2 with the boot light and not the VGA white light
Progress~!
