Since it's Black Friday and nearly Cyber Monday, I wanted to build a PC since I've been a light gamer for the past 2-3 years. I've always been buying PCs that weren't exactly meant for gaming since I didn't play that much. Recently, I've noticed that I'd like to build my own since it's significantly cheaper rather than buying a new one because mine has been running slower in FPS over the years.
I frequently play League of Legends (fps has been unstable from 40-100) and Maplestory 2, but I'd like to run Blade and Soul more smoother as well as Ring of Elysium since they both frequently crash.
I'm new to building so I honestly have no idea where to start off. I'd like something that can run all of the above games fairly well at 60FPS while being able to stream videos. I may plan on streaming, but nothing too serious. I also usually have 20-30 tabs open, don't shut down my computer often, and I'm usually in Discord calls, but I'm not sure if this affects anything.
My budget is $800 and it'd be great if it was under $500. I'm able to go a little over my budget if needed!
Thank you.
Thank you.
