Alright so ive recently started putting together a new system
p6t deluxe v2 (socket 1366)
core i7 920. 2.66
12gb ocz platinum
2* xfx 4890 extreme
my case is going to be Haf 932, and i want to try my hand at water cooling the bad boy, so ive been researching and pricing out parts and heres my list so far
Blocks -
Koolance CPU-350AT LGA1366/LGA775/AM2+ Universal CPU Water Block G1/4 Threads
Koolance VID-487 Full Cover GPU Water Block for Radeon HD 4870 & 4890 Video Cards G1/4 No Fittings
reservoir -
Swiftech MCRES-MICRO REV2 Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
Radiator -
Thermochill PA120.3 Triple 120MM Fan Water Cooling Radiator with 15MM Spacing *No Barbs*
Pump -
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Ek Water Blocks EK-D5 X-TOP Version 2 Custom Pump Top for D5 & MCP655 Pumps G1/4
Fittings -
Koolance Single G1/4 Swivel Angled 3/8 Inch Threaded Compression Fitting
Bitspower G1/4 Straight Compression Fittings for 1/2IN ID 3/4IN OD Tubing (Pair)
Tubes -
Primochill Primoflex Pro LRT UV Blue 1/2IN ID 3/4IN OD Tubing (10 Feet)
Primochill Primoflex Pro LRT UV Blue 3/8IN ID 5/8IN OD Tubing (10 Feet)
additives -
Feser One Feser View Blue UV Reactive Dye Water Additive 50ML Bottle
misc -
Reducing Socket G1/4 to G3/8 Inner Thread
Reducing Socket G1/2 to G1/4 Inner Thread
so what do you guys think, do i have everything i need, if not what else also is everything compatible, are the sizes of all the fittings and the tubes gonna work,
is there better stuff i can buy, also i live in canada so i had to use ncix(canadian) to get all the components
if theres a better site for water cooling products that ships to canada for a fair price i would like to know,
anyways basically i want to know if these parts are good or not, if they'll work together or what other parts i would have to get
please help a beginner out
core i7 920. 2.66
12gb ocz platinum
2* xfx 4890 extreme
Blocks -
reservoir -
Radiator -
Pump -
Fittings -
Tubes -
additives -
misc -
