Just assembled a new build with an extreme4 z77 mobo. Wouldn't power on at first. Checked the psu by jumpering the green and black wires (4th and 5th ones in on the 24 pin connector). PSU checked okay. Forgot the jumper was there and plugged it in with psu off and unplugged. When I power on the psu, case fans come up, I/O panel illuminates, and the power switch then will fire everything up.
Jumper can be removed with system up and running and all remains well. Loaded windows, several restarts went fine. However, when fully shut down, the system will not power up again without jumping the 2 wires long enough to hit the power (on) button.
No codes at all on the debug panel, and the "on (mother)board" power button acts the same way as the button on the case. Once up and running everything works fine, but when shut down fully (not shutdown-restart) it will not power up without the jumper being there - as soon as you press the power button the jumper is no longer needed.
System specs are:
3570k
Corsair H100 cooler
Z77 extreme4 (asrock)
2x4gb corsair vengeance ram
Tx750m Corsair PSU
C70 Corsair case
What am I missing? Help!
System specs are:
3570k
Corsair H100 cooler
Tx750m Corsair PSU
C70 Corsair case
