It is likely I will be a little over detailed here, but I need the help and want to provide all information that might be relevant. Sorry if I get a little over wordy.
When I started this build I ordered the 256GB Critical M4 MSATA SSD thinking I could use my 500GB SATA HDD as a file drive and run the OS, Games, and 3D rendering apps from the M4. Soon after ordering I noticed a thread detailing the limits of MSATA due to its PCI constraints. So I rethought my build. I ordered a 240GB Corsair Force GS SSD for my OS and applications and would use the M4 to store my system backups.
Now, with the OS and apps installed on the GS and the M4 for my back-ups, I am not satisfied. My drives are filling up to quickly. I guess I am used to having a lot of head room, seeing a new drive at half capacity after a couple weeks is just to much. So I ordered another GS and it arrived yesterday.
Yes.. TRIM active, system restore off, hibernate off.
This is what I think is my only option, suggestions welcome..
Please remember I have NO idea how to do this.
Could I put the two GS drives together in a RAID 0 configuration, configure the M4 as a file storage drive, and use the HDD as a hot swap to install my backups once a week.
Does this design make sense?
How do I do this? There a thousand threads but which to follow?
Will I need any special RAID drivers? Motherboard manual says to use USB but where do I get drivers?
I am sure I cannot save everything, but can I at least save the configurations for my apps like, Precision X (took me 2 days to get a good stable overclock), Steam, and all those $%# updates.
I have moved all docs and videos to the HDD in preparation but I do not know how to move or where to find anything else.
Thank you for your time.
