I saw a recent question about whether using the second (lower) PCIe slot would reduce graphics performance, but I have a different question. And sorry if this is a stupid one:
Does using the lower PCI x16e slot (in a motherboard that has one) risk slowing down the top (GPU) slot and GPU performance?
I'm splurging on a high end build: ASUS Formula Z690, RTX 4090, i9 13900k. There's a note on the ASUS site regarding the Forumula, though, and I suspect this isn't unique to this board only:
I'm not planning to run two GPUs ever, so the RTX 4090 will go in the top slot, but I like the idea of the lower slot as potential future proofing. Specifically, it would be comforting to know if I could use that slot in the future for PCI 5.0 SSDs (that should be possible, right?). But the note above seems to be saying that if I use one PCI x16 slot, it will cause the other slot to run at x8. I know this is specifically relating to this ROG Hyper M.2 card, but would the same apply to any high-bandwidth card that I put in the lower slot? In other words, is there limited bandwidth that's shared between the two PCI x16 slots, and using both will limit the bandwidth available to the GPU in a way that might affect performance?
I'm aware that I'm making a small trade off on future proofing by going with the a Z690 board now that Z790 are available, but from what I can tell as a novice, there shouldn't be much/any performance difference at stock speeds and probably not a big difference on OC performance except at the higher ranges. The Formula matches the white aesthetic I want, but doesn't have PCI 5.0x M.2 slots. That speed seems excessive anyway for my use case (gaming/office), but it would be comforting to know if it is possible to upgrade later using my second x16 slot.
Thank for any advice/reactions, I'm psyched for this build but feeling very ignorant right now.
Intel® 13th & 12th Gen Processors*
2 x PCIe 5.0 x16 slot(s) (supports x16 or x8/x8 mode(s))**
Intel® Z690 Chipset***
1 x PCIe 4.0 x16 slot (supports x4 or x4/x4 mode)***
* Please check PCIe bifurcation table in manual Chapter 1
** When ROG Hyper M.2 card is installed on PCIEX16(G5)_1, PCIEX16(G5)_2 will run x8 only and if ROG Hyper M.2 card is installed on PCIEX16(G5)_2, PCIEX16(G5)_1 will run x8 only.
*** Supports Intel® Optane Memory H Series on PCH-attached PCIe slot
