Title says it all really. About to get the above CPU on a P5Q-E (ebay purchase). Seller said he had it running solid a 4GHz but was using water cooling (which isn't part of the purchase) and I'm not sure I'm ready to go down that road so will stick to air. I'd like a solution that's going to do the job and do it quietly as I'm also putting a quiet GPU and PSU into the system, along with some sound dampening foam into the case.
Would really appreciate some suggestions.
just buy a silent fan and put that on it instead of the stock fan that comes with it. make sure not to get the EE 1283 though..
