Question Newbie here, need help overclocking my ram
Dec 27, 2019
Can anyone help me overclock my ram, I have Asus Ex-A320 Motherboard, AMD Ryzen 3 2200g CPU and Single stick T-Force Delta R 8gb 2666 mhz Ram.
BTW (grab second ramstick for ~30-50% more FPS) dual channel can give you way more than OC.
its supported out of the box, and cpu can do dual-channel DDR4-2933.
IF you watch this:
View: https://youtu.be/7RF6UUZlgVs?t=393
it shows you how to configure it.
If you manage to pick something that does not boot, removing power and
https://dlcdnimgs.asus.com/websites/global/products/rdhmj6pnbxnjm9bv/images/mb/mb-mobile.jpg
battery ABOVE number 7, for a minute will reset it back to default. (I could not find a good image of your mobo, but battery is the same, just a different place.
