I am new to upgrading. I have a nVIDIA 8800 GT w/ 512mb and a power supply on order. It started that that was all I wanted to do. Then I decided that I would later build an SLI system around the card later. Then the idea hit me to just upgrade my current Computer, to avoid buying things like a new case, optical drives, hard drive, and OS. So my goal is to upgrade the CPU, motherboard, etc, without having to buy windows and all that.
My Systems Current Specs:
HP Pavillion a1700n
Vista Home Premium
CPU: AMD Athlon 64 X2 3800+ 2.0 GHz, Socket AM2
Chipset: 6150 LE
Motherboard: Asus A8M2N-LA
I know the form factor is ATX
Can I add a more powerful CPU as long as it is 64 X2, and AM2 to the current motherboard w/out affecting windows vista? What all is involved in getting it to work properly?
I am looking at this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2905661&CatId=2328
At a later date I would like to upgrade the motherboard with one with a nVIDIA chipset and SLI compatibility. The current motherboard is microATX, will regular ATX work, I can’t find a single microATX that is SLI ready. Also, I have read there can be a problem getting windows to run right, at least with XP.
So in short, I want to in this order:
Add graphics and power supply, update CPU to current motherboard, and at a later date when I have the money for second card and motherboard, add those.
Any help would be appreciated, or if someone could point me in the direction of good resources would be great.
HP Pavillion a1700n
Vista Home Premium
Chipset: 6150 LE
