Newbie needs help with connecting power Evga 1200 supernova P2 PSU to Supermicro X10SRA 2011-3 MB
PeterZ640
339
I need help on a few poinrs
A] There is a 5 Pin ( yes 5 ) connector called JP12CI [pwr 12C] on the MB, in the manual it says it is"The Power Supply SMBbus 12C Header" , the description later in the manual under connecting cables says ...
Monitors the status of the power supply, fan and system temperature.
Should this be connected,? And if so how? The pin out says .. 1.Clock, 2. Data, 3. power fail, 4. ground, 5. 3.3 V
[ note this is just after a section entitled TPM Header. I think this is some sort of extra thing for remote management stuff]
Its a bit confusing as the manual also covers the X10SRA-F board, in a few places it says "only supported on the X10SRA-F" - but doesn't say that here.
NB there is also a 24 Pin ATX Main powerplug and an 8 Pin CPU Power plug (JPW1 and JPW2) both say they are required, [I understand these ones]. Except the scematic diagram labels JPW2 as a "12V 4 pin CPU power connector, its actually physically an 8 pin, and later in the manual calls it an 8 Pin connector [ I assume its a typo error? ]. I assume I just put together the 2 halves of the 12V 4+4 pin EPS Power connector on the PSU and push them in together
B] there is also another 3 Pin connector called "Standby Power Connector" STBY1. What do I connect that to on the PSU? Or do I ignore it?
On the Supernova 1200. i only have the 24 pin, and 2 x 8 or 4in plus 4pin EPS Power commectors.
C] The MB has a 5V 3 Pin DOM power connector for. Disk on Management device - I Assume I should Ignore this connection?
D] the Supernova comes with a lot of cables. Some connection on the back say VGA or PCIe 6+2 and a few have PCIe 6.
Is the 6 pin block exactly the same as the 6 pin part of the 6+2?
Sorry to ask such basic questions, but the Supernova manual is very basic, and sparse in technical content. In addition all the wires in the cabling are black. And no pin definition is given on the EVGA Manual or case back.
Thanks
4K is of very limited value at the range most people watch video. Gaming a less than a meter, it matters, but at normal viewing range, it's hard/impossible to tell the difference.
Yes, for 4K ,more video RAM for the GPU is good, but we will need to see how DX12 changes the calculus.
That's a great PSU and the sort of thing I would recommend if you had chosen something shoddy.
Hi. The motherboard you are using is also used for workstation, high reliability computation, and server use, and supports extra features for that purpose.
I'm assuming you are using it for gaming or rendering/editing/3D modelling. In that situation, all you need is the 24 pin ATX and the 8 pin JPW1 and JPW 2. Yes you just smoosh the two halves together. They should sort of lock together.
None of the other power connectors are supported by your PSU directly, I think.
The PCIe 6 and PCIe 6+2 are for GPUs and the 6 part of the 6+2 is identical to the standard 6. The 6+2 allows for a lot more power to be delivered to the GPU (75W for 6, 150W for 6+2)
What are the rest of your components and what are you using the system for?
Hi
Thanks for the detailed response. Much appreciated as it is my first ever build.
And for me the components are quite expensive - so prettty scared I will blow them up. Lol :-/
The system is in a Phanteks Evolv ATX Case, cos it gave me 180mm cooler height.
The motherboard is SM X10SRA, not the F variant, which seemed to me to be more focused towards the server orientated market with tons of remote management stuff I neither understand nor hopefully need.
The processor is the Xeon E5 1650 V3 3.5 ghz turbo 3.8 Ghz, 6 Core. - choosen for relatively high clock speed for a Xeon, well at least in my price range. ECC Ram, and can support more ram than I can afford! And 40 lanes for throughput. Also supports 40 lanes.
A Noctua NH-D15 - twin fans, apparently good per reviews
An Intel 750 400 GB PCIe SSD, alledgedly quite fast, anyway all I can afford. This runs the OS if I can get it to boot :)
And initially the programs.
32GB ( 2x16GB ) Samsung ECC 2133 RAM - 'cos its supported and there was a deal £ on!
A samsung 850 EVO 500 GB SSD - to quickly archive my work to. If I dont get a good price for my laptop, then another samsung 500 GB 850 Evo - used 3 months ago to upgrade the Laptop.
5x Noctua 140mm case fans and one 120mm case fan ( if I can mode the case to fit the 120mm fan, so I have positive case pressure.
A Pioneer BDRS09XLT 16x Blu Ray - DVD readwrite. Need a DVD reader for Photoshop, Portraiture and Office and Canon DPP.
A MSI Gaming 4GB 970 Gaming 4G Graphics Card - hopefully it will Drive the HP 24" IPS 4K screen.
Intel Wireless AC - 7260 to get to my BT Infinity wifi.
An Asus Hyper M.2 X4 Mini Adapter PCIe card [ bought as this MB has no M.2] if the cooler can go vertical, then this will fit in, and then house a Samsung 950 Pro M.2 500GB SSD [ basic idea was to then put the application software like Photoshop and any files I am editing on this drive and just have the OS on the Intel] . But I need advice if this will go as fast or faster if I split the OS and the application programs. My thoughts are, if I have an Application problem at least I can format this drive drive and load again, without reloading the OS. Previously sufferred with Photoshop and Elements.
Will buy next week a Cyberpower PFC 1500W UPS. Not sure if one needs one? Guess if the Bios is up todate, and the PSU handles our power , I may abort this.
We have from time to time a really fast blink on the lights??
Usage: Editing still images 80 to 160MB each, say 400 to 900 shot in a day.
Later to do some 4K video editing ( currently edit the odd small 1920x1080p FHD videos )
Hi
Thanks
The PSU I chose is a EVGA Supernova P2 1200watt. Inside its really a Superflower so apparently very stable. And way overkill powerwise. As my total watts are about 650 watts
Unfortuneately the first one was very noisy, really intrusively loud - and then it refused to turn on. After about 22 attempts it then started ( well in test mode )
Luckily my supplier SCAN is very good and a replacement arrived the next day. Much quieter and turns on everytime. :)
No interest in Gaming but appreciate the advice. Just stills editing and a small amount of video editing 1920 x 1080p at the moment. Maybe late next year some 4K video ??
I went cheap because if 4K video crucifys it - I would rather invest in a Pascal based 980 or whatever they come out with ... Also I will need a lot of advice before lashing out on that i.e. Does one need more video RAM than 4GB etc.
My thoughts were sell the 970 if it cant cope.
There is no rush, I I only got the new Canon 5DS R 50MPS camera and surprisingly t didn't have 4K video.
Weirdly there doesnt seem to be much demand for 4K. Actually a number of people I did cameo videos for, such as a "fire eater" wanted very low quality for UTube or something. Beyond me ! :-/
Thanks
What is DX 12? Is that Pascal ?
What I dont like about the EVGA is having a daisychain of 3 at the SATA Or PCIe end of their standard power cables. Plus they have unique ends at the psu end and very expensive cables with single ends
The cables are rated for the load and it keeps the number of cables running through the case down to a reasonable amount. Many GPUs that would use that PSU might need two 6+2 PCI-e connections, and it is much easier if they are both on the same cable. If one were to run 4 x Crossfire of weaker cards, eight PCI-e connections might be needed, so two per cable is about the only way to do it.
For the SATA, it again makes it convenient to power a couple of SSDs from a single cable, keeping the clutter in the case down. I use and recommend the EVGA 110-B2-0750-VR and find the cables to be convenient.
Microsoft DirectX is a collection of application programming interfaces (APIs) for handling tasks related to multimedia, especially game programming and video, on Microsoft platforms. Originally, the names of these APIs all began with Direct, such as Direct3D, DirectDraw, DirectMusic, DirectPlay, DirectSound, and so forth. The name DirectX was coined as shorthand term for all of these APIs (the X standing in for the particular API names) and soon became the name of the collection. When Microsoft later set out to develop a gaming console, the X was used as the basis of the name Xbox to indicate that the console was based on DirectX technology. The X initial has been carried forward in the naming of APIs designed for the Xbox such as XInput and the Cross-platform Audio Creation Tool (XACT), while the DirectX pattern has been continued for Windows APIs such as Direct2D and DirectWrite.
Direct3D (the 3D graphics API within DirectX) is widely used in the development of video games for Microsoft Windows, Sega Dreamcast, Microsoft Xbox, Microsoft Xbox 360, and Microsoft Xbox One. Direct3D is also used by other software applications for visualization and graphics tasks such as CAD/CAM engineering. As Direct3D is the most widely publicized component of DirectX, it is common to see the names "DirectX" and "Direct3D" used interchangeably.
The DirectX software development kit (SDK) consists of runtime libraries in redistributable binary form, along with accompanying documentation and headers for use in coding. Originally, the runtimes were only installed by games or explicitly by the user. Windows 95 did not launch with DirectX, but DirectX was included with Windows 95 OEM Service Release 2. Windows 98 and Windows NT 4.0 both shipped with DirectX, as has every version of Windows released since. The SDK is available as a free download. While the runtimes are proprietary, closed-source software, source code is provided for most of the SDK samples. Starting with the release of Windows 8 Developer Preview, DirectX SDK has been integrated into Windows SDK.
DirectX 11 came out with windows 7 11.1 with Windows 8 11.2 with Windows 8.1 and DX 12 is pert of Windows 10. Developers need to take advantage of its capabilities to the fullest extent, so we await DirectX 12 games and other applications.
