Question Newbie - Problem with CPU coolers - stupid question?
Aug 16, 2019
4
Hello,
So I'm upgrading my computer, bought a new Rizen 7 3700x that came with the wraith prism and was installing it on a new motherboard Rog X570.
I wanted to use my old Corsair H100i with the Rizen 7 but apparently I must have thrown away the AMD Brackets and doesn't fit.
I know Corsair would be a better option, but I guess I can live with the wraith prism.
Question is (sorry for my ignorance): Can I still use the fans from the Corsair H100i to cool down the rest of the computer? Like to use the wraith prism to cool down the CPU and the fans from the Corsaire also connected to the motherboard to take some heat away from the computer... does it make sense? is that actually possible?
Thank you so much <3
Aug 16, 2019
4
Thanks for the prompt reply, yes i checked on the Corsair page but the bracket is out of stock now : /
Then what double case fan would you recommend to take out as much heat as possible? thanks again
