I'm relatively a newbie with tinkering with PCs, so please bear with me if this is common knowledge.
I have been monitoring my CPU temp for once and decided that my PC needs a quick clean up as it was reaching temperatures of 100 C during use. Cleanup was straightforward until I decided to take off the CPU fan / cooler. I have no knowledge on if what I did was correct, but i detached the four plastic screws on each end of the cooler after unscrewing them. Finished my cleaning and attempted to reattach my cooler only for it to not fit on all four holes on the motherboard. While attempting to reattach it, I've even broken one of the plastic bits of the screw, pic below.
I'm wondering if this cooler is still usable? Considering that the other three pins are still intact, and even then I'm not sure why I am unable to screw them back in. I read that the black pins should be retracted before I attempt to reattach it, but I can't seem to pull them back up so that the white screws are in front. This is a relatively old PC, and I'm assuming that it is a stock cooler from Intel. Here is what is written on the front, if the name of the model helps in any way.
I'm hesitant to buy another cooler as my budget is currently very tight. If I am unable to reattach this cooler traditionally, perhaps I could use something like duct or cello tape? Or perhaps laying the PC flat so that the cooler stays upright? My main problem right now is that I am unable to fit the screws into the holes, and that I'm unable to move the screws on the fan vertically so that I can retract the black piece of the screw.
Any help would be greatly appreciated.
