Take a look at this cable:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200374&Tpk=N82E16812200374
I was told I needed to purchase this along with a Sony slimline slot load optical drive.
I have the two red cables attached to the drive and the other end of the red cable to the mobo.
What do I plug the white one into? I am assuming an IDE power plug?
This is a new build. When the machine powers up everything is fine in bios except it doesn't recognize the drive. Says "Sata 2 Incompatible Press F1 To Continue". The drive makes no noise, has no light, etc.. Almost like there is no power.
I am trying to load Ubuntu but can't as the drive ain't alive.
This is my first build and everything went fine until this happened.
Bios does not recognize the drive at all. I assign it CDROM and changed the boot priority. Still the same.
Is the drive DOA? Do I have the white plug in the wrong place. The SATA HD wasn't recognized until I plugged that into the motherboard with a cable that came with it. The problem is the plugs on that cable are SATA.
HELLLP!
HELLLP!
