I built a computer recently that now won't power on, even though it has run fine for the past 2 weeks I've had it. Now when I try to power on it simply doesn't boot whatsoever, though any USB peripherals that are plugged into the PC still light up. When I turn the rocker switch on the PSU off then on, when I first press the power button on the front of the computer I hear a very slight click and the USB peripherals turn off for about half a second then they turn back on. This happened first this morning when I was using the computer and it all of the sudden shut off. It was doing these symptoms and later in the day I tried turning it on again and it worked. Then this all happened again just now. What could be the issue? Here are my specs:
500W PSU
i5-3570k CPU
2x8GB RAM
GTX 760 GPU
500W PSU
i5-3570k CPU
2x8GB RAM
GTX 760 GPU
