newly build pc restarts after 10 secs after the power button pressed, no post and no sound
funnyjormoyable
4
i do not have a post speaker connected to the pc so i cant use the post beep as an indicator, the fans all go and then die slowly then restart
heres my specs:
Intel Core i5-4590 3.3GHz Quad-Core Processor
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard
Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1866 Memory
Samsung 840 EVO 120GB 2.5" Solid
Western Digital WD Blue 500GB 2.5" 5400RPM Internal Hard Drive
XFX Radeon R9 290 4GB Double Dissipation Video Card
Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case
Power Supply
Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive
Samsung SN-208DB/BEBE DVD/CD Writer
if pics are needed i will provide
i'll try and get back to you.. i think i also need a bigger psu, 750w is minimum for the graphics card
