Newly build pc running extremely slow
superjoker813
So I just build a pc for the first time but I had loads of knowledge about it but its been running very slowly.What is really wierd is that on 3d max fire stricke nenchmark i got 11000 which is really good.On the other hand on this benchmark http://www.userbenchmark.com/UserRun/6155913 i got really bad scores and the ram is highly effected.
max core temperature was only 44 Celsius
Spec:
ryzen 5 1600
ASUS GeForce DUAL-GTX1060--O6G 6 GB Graphics Card - Silver
EVGA 430 W1, 80+ WHITE 430W, 3 Year Warranty, Power Supply 100-W1-0430-K3
GIGABYTE GA-AB350M-Gaming 3 AMD Ryzen CPU AM4 Socket DDR4 PCIe Gen3 USB 3.1 GB LAN Micro ATX Motherboard
Seagate Barracuda 7200 Desktop 1 TB Hard Drive
Corsair CMK8GX4M1A2400C14 Vengeance LPX 8 GB (1x8 GB) DDR4 2400 MHz C14 XMP 2.0 High Performance Desktop Memory Module - Black
Code:
To be honest, it looks like your scores are fairly average for the hardware. Could just be that you are only using single channel ram, and using quite slow ram (Ryzen works best with faster ram).
