• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Newly built computer not booting up! Help Plz!
G
Guest
Guest
I just finished building my computer and tried everything possible, tested out my power supply, plugged and rotated around my front panels cable and still didn't change anything and I've done steps for troubleshooting it and still nothing, if anyone got any ideas on the matter, plz let me know
G
Guest
Guest
When I press the power button nothing turns on, not even the fans and I looked up my motherboard's manual to see where all the cables went and did it by that.
SimonGranstrom
319
45
I am not a expert at this, since i have only built two computers which both started at the first try.
It sounds like the motherboard is not getting power, check if the 24-pin power cable is connected all the way until it locks in place.
G
Guest
Guest
You probably know more than me anyway, so checked the 24-pin it was well in there and I'm really running out of things to check to be honest, is there anything else you can think of?
SimonGranstrom
319
45
Do like this: Take a flat screwdriver or a flat metal object, put it so that it touches both power + and power - where you normally plug the power button. Might be something wrong with the case power button.
G
Guest
Guest
That didn't do anything either and I don't think there would be something wrong with the motherboard, it's brand new. Do you want to know my specs, maybe it may help?
G
Guest
Guest
Motherboard: Asus p8z77-v
PowerSupply: Corsair VS550 ATX
GraphicsCard: Gigabyte GTX650
CPU: I5 3570K
Ram: 8GB
There's some hard drives and cd drives
G
Guest
Guest
I think I do, it's one of those bolts looking thing yeh?
G
Guest
Guest
I tried the power supply and the power supply's fine, I just took out the motherboard and I'm putting it back in now seeing if that's makes any difference..
SimonGranstrom
319
45
Yes it's a couple of them, and you place them between the motherboard and the case so that the motherboard doesn't short circuit.
FastGunna
532
72
Just because you didn't mention it and nobody has said anything about it yet, did you flip the switch on the power supply? I read another thread awhile ago where this was the problem.
G
Guest
Guest
Yep. I've done that
SimonGranstrom
319
45
He tested the power supply and he claims that it is working so i assume he has it powered on.
G
Guest
Guest
Yes, and I bet they felt really stupid after finding that out aha
FastGunna
532
72
Yea I typed mine before he posted that but my phone is going slow today. Decided to leave it because it was still a possibility (though slim)
Don't put it back. Put it on its box, connect the power supply and see if the CPU fan is spinning when starting the board.
USe the scrediver method for starting the board.
y4nn1c7
15
Similar threads
