Hello,
Recently built a new PC, here are the specs:
Ryzen 9 3900X CPU
MSi Tomahawk X570 ATX motherboard
EVGA XC3 RTX 3080 GPU
G. SKILL F43600C18D64GTZN 2x32GB DDR4 3600mhz CL18 kit
Whenever I enable XMP or manually overclock the memory to anything over the default 2666mhz speeds, my PC will experience crashes and BSODs playing games or simply idling. I have tried using DRAM's calculator settings but it would not post even with the safe calculations and have ran memtest86 which shows errors whenever I run the memory at any speed over 2666mhz. I did not build this machine to run memory at 2666mhz so I am wondering if there are any other fixes you guys know of or should I just get a new memory kit and if I do what is recommended for my specs.
Thanks!
Ryzen 9 3900X CPU
Thanks!
