So I ordered everything for a new PC from newegg, except power supply & keyboard... here are the specs:
CPU: Core2Duo E4400
Mobo: Abit Fatal1ty FP-1N9 SLi
RAM: 2x 1GB G.Skill DDR2-800 4-4-4-12 (rated @ 2.0 volts)
GPU: HIS Radeon HD2900 XT 512MB GDDR3
HD: 2x 250GB Seagate 7200.10 SATA2
DVD: Lite-On 20x SATA DVD BURNER
Case: Antec P180B w/3 TriCool fans
CPU cooling: Thermalight Ultra 120 Extreme w/ AeroCool 120mm fan & AS5 thermalpaste
USB/PS2 keyboard, Logitech G5 mouse
Monitor: 20.1" widescreen LCD, 5 ms (Spectre X20)
PSU: 600W Ultra X-Finity (18A & 20A on 12V rails)
Problem:
Fans turn on, motherboard lights up. Keyboard blinks on then off when plugged in (so PS2 port has power). No beep, no display, keyboard LEDs don't work. Computer just sits there with fans running and lights on, doing nothing.
What I've done so far:
Reset CMOS. Didn't work.
Tried a new CPU (went to Fry's and bought a E4300). Still doesn't work, so CPU is fine.
Removed RAM and booted system. No error beeps.
Tried RAM from another system, and tried this RAM in another system. RAM is fine.
Tried turning on system with no video card in case there was too much power drain... obviously display wouldn't come, but the keyboard is still unresponsive (I should've been able to turn on/off the LEDs if the system booted up).
What I think is the problem:
Defective motherboard, or some incompatibility.
What I need:
Your advice & help!
Thanks!
CPU: Core2Duo E4400
Problem:
What I need:
Your advice & help!
Thanks!
