[SOLVED] Newly built PC internet connection problem
Jun 14, 2020
Hello,
I hope you all are fine.
I recently built my own gaming desktop PC. All is working fine except that I can't connect to internet (unidentified network).
I am trying to connect with an Ethernet cable.
To be more specific, every component of the PC is new....except for the Hard Drive (2,5'') that I used on my former laptop.
Nonetheless I deleted all the files in it by rebooting Windows 10 with a Flush Disk from BIOS settings. By doing so I wanted to get rid of useless drivers which would cause compatibility problems. Once Windows 10 installed, I donwloaded the right Chipset and Lan drivers from my motherboard manufacturer's website. I still don't have access to internet. The problem isn't coming from the cable nor the the modem nor the plug.
A strange thing is, I had internet for a couple of hours today before loosing it again.
I read tons of thread about this problem but couldn't solve it.
Any help would be appreciated.
Best regards,
I couldn't intall the BIOS update.
The file in the extract is a .cap, my laptop doesn't recognise it and doesn't know how to open it. When I transfer it to my newly built desktop, it says that I need to download codecs from Microsoft Store but I can't since I don't have internet on this one.
No no no.... Format a usb tocopy the .cap file to the usb then restart you pc booting into bios use asus ez flash tool to update bios.
Hello,
Best regards,
Please post system specs
Jun 14, 2020
Hello,
Here they are :
Motherboard: ASUS TUF B450 plus gaming
Processor: AMD Ryzen 5 3600
Graphic Card: AMD RX 570 Armor 8gb OC
16gb RAM
1Tb 2,5'' Harddrive
Software: Windows 10
Jun 14, 2020
