Hi,
Just built my first PC (as only ever used Laptops), however, turning it on for a test run, straight away an incredibly loud noise/buzz/whine comes from the system, so much so that the system then shuts down after about 10-15 seconds. Then after a further 10 seconds, it reboots itself and repeats. I got quite worried so turned the whole thing off and even after turning it off, the whine continued so it seems to be either from the GPU or Fan.
The specs are as follows:
CPU: i7 5820k
GPU: EVGA GTX 980Ti FTW
Motherboard: Gigabyte X99 SLI
CPU Cooler: Noctua NH-D15 (i'm only using one fan as the other would be too close to my 24pin connector.
Also 2 Case fans.
Case: Factral Define R5
PSU: Corsair HX1000i
The good thing is, all fans are running when I turn it on so seems at least connectors are fine, but I'm really worried to damage that card. Is there any way I can troubleshoot where all this comes from?
Thanks
Loos
CPU: i7 5820k
Also 2 Case fans.
Thanks
Loos
