Newly built PC no display, help please!
Jake Johnson
24
So this is my first built pc with some help from an experienced friend of course.
Components:
Gtx 980ti sc
32gb ddr 4 ram
Maximus viii hero mb
I7 6700k proccessor
Evga 850 gold psu
Cooler master water cooling
Pc turns on perfectly fine, altough no video, no beeps nothing. What could it be?
Okay sorted it out.
Incase some other newbie has the same problem.
Install your windows first using your motherboard display input, and once installed then you can throw in the graphic card, and it should be fine.
I would remove the video card and try to boot it. if still nothing then remove the ram then boot you should hear a beeping noise, if not then re-seat your CPU. still nothing? you have a motherboard or a CPU issue.
Thanks ss202 ill have a look at that.
Thanks problematic ill give it a try and update the thread appreciate it.
Ps: I had forgotten to connect the cpu power to the power supply, might of left out something else. But ill try the mentioned above first
Okay sorted it out.
