[SOLVED] Newly built PC turns on, but the monitor, keyboard and mouse do not work.
Jun 23, 2020
9
Hi,
I recently built a PC and it doesn't seem to POST. All the fans connected to the motherboard turn on, including a couple RGB strips connected to an aura pin. There aren't any LED's on the GPU so there's no way of telling if that's getting power, but it doesn't look like it is since the monitor isn't getting signal. The keyboard and mouse do not come on either. Is there anything anyone would recommend I try?
Thanks.
rgd1101
motherboard support 8th/9th gen only
rgd1101
Jun 23, 2020
9
I can't believe I missed that when ordering the parts. Thank you so much, wouldn't have figured that was the issue.
