Newly built pc won't display
FreakyCat
Commendable
Oct 29, 2016
I just built a pc but it won't display. Everything turns on like it should but when i connect a monitor it just doesn't display Gpu: Geforce GTX 1070
Cpu: Intel i7 6700k
Another quick question should i connect the monitor through the Gpu or the motherboard?
Please send quick awnsers
Thanks
It still doesn't display i have coneted to the gpu. I a have corsair rm 650x which should support it...
Did you plug in the power cable to the graphic card? its usually 6pin cable
usually people forgot to connect the power cable to graphic card because they think what they need to do is just put the card on its slot
