Newly built PC wont fully start up
Infernius
6
Newly built PC turns on for 5-7 seconds, fans start spinning, then it shuts off for 1 second before starting up again and repeating cycle until psu is turned off.
PC Specs
Intel Core i5-6600K 3.5GHz Quad-Core Processor
CRYORIG H7 49.0 CFM CPU Cooler
Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard
G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory
Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Sapphire Radeon R9 390 8GB Nitro Video Card
NZXT S340 (Black) ATX Mid Tower Case
EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Problem persists
``Problem persists ``
look weird but its a good news
so maybe a short somewhere ... did you install the standoff correcly and at the good place??
did you install the cpu correctly or bent pins and thermal paste well applied ??
did you tried with only one ram at the time?
your psu worked well???
Reinstalled standoffs and am pretty sure they're all in place. thermal paste well applied, tried with one ram, PSU apears to be working but it may not be providing enoguh power, i don't really know.
Kinda sounds like the BIOS is freaking out. Are you able to do anything, maybe boot into the BIOS to monitor?
If not, usually the CPU overheating would just cause it to power off, and not cycle.. Have you tried only CPU, 1 stick of RAM (multiple slots), and onboard graphics only? Disconnect drives and graphics card.
