Newly built system - CPU fan very noisy on start up
cainy393
14
I've just built my firt rig this afternoon and I'm currently installing the OS. Whilst building I accidentally hooked up the power and started up to test the components, but I had forgotten to put the CPU cooler. I quickly realized and switched off after only a couple seconds.
Now, when I boot my PC, the fan is silent until just after the post beep when suddenly it goes really, really loud. After a few seconds it slows down to a normal pace. Could my earlier mistake have caused this or is this a normal occurrence. Thanks in advance.
I have seen boards do that in the past.
My X58A UD5 does something similar, my fan does not even spin up right away then it revs up(this ensures the fan is spinning before slow down) and slows down.
Your cpu has built in protection, it is not good for it, but one time should not have killed it.
Also check the bios to see if it is set to PWM or Voltage for the cpu cooler. Some boards do not rev pwm fans. Then again others do it with all fans.
