D Djlewis12 Honorable Dec 17, 2013 26 0 10,530 Dec 28, 2013 #1 My current video card is a Nvidia Geforce GT 610. What's the next step up from this card that would actually make a difference is performance?
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Dec 28, 2013 #3 A gtx 620 up would increase performance, give us a price then we can give you an answer. Upvote 0 Downvote
D Djlewis12 Honorable Dec 17, 2013 26 0 10,530 Nov 4, 2014 #4 Gam3r01 : A gtx 620 up would increase performance, give us a price then we can give you an answer. is gtx a better series than gt, or is there no difference? Upvote 0 Downvote
cowboydude99 Honorable Aug 21, 2013 1,493 0 11,960 Nov 4, 2014 #5 We really need your budget, cpu, motherboard and psu to make sure you can power the card and there won't be a bottleneck. Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Nov 4, 2014 #6 GTX is typically the more "gaming" lineup of cards. Upvote 0 Downvote
D Djlewis12 Honorable Dec 17, 2013 26 0 10,530 Nov 11, 2014 #7 Gam3r01 : GTX is typically the more "gaming" lineup of cards. http://www.amazon.com/EVGA-Superclock-Dual-Link-Graphics-02G-P4-3753-KR/dp/B00IDG3IDO/ref=sr_1_1?ie=UTF8&qid=1415742720&sr=8-1&keywords=gtx Is this a reliable card for gaming? Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Nov 11, 2014 #8 Its a good entry level card. It can run almost any game with decent settings and FPS, while drawing very little power. Upvote 0 Downvote
D Djlewis12 Honorable Dec 17, 2013 26 0 10,530 Nov 11, 2014 #9 Gam3r01 : Its a good entry level card. It can run almost any game with decent settings and FPS, while drawing very little power. So do you think it could handle the newer titles like AC Unity or Far Cry 4? Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Nov 11, 2014 #10 Not likely, considering Unity is requiring a 680, and recommending a 780. Upvote 0 Downvote
D Djlewis12 Honorable Dec 17, 2013 26 0 10,530 Nov 11, 2014 #11 Gam3r01 : Not likely, considering Unity is requiring a 680, and recommending a 780. I see. But either way its still a good upgrade from my current card right? The gt 610. Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Nov 11, 2014 #12 Yes, it will be a substantial upgrade. It can run BF4 on ultra no AA at 28FPS for example, ACU is just a poor quality port with much too high system requirements. Upvote 0 Downvote
