nForce 790i sli 3 motherboard running 90 degrees Celcius help!!!
brotherjames1259
nforce 790i ultra sli running System Temperature 90 degrees celsius
recent changes
put in 8 gigs of ram and installed windows 8 x64 bit
graphics card is normal 50 degrees celcius
CPU is normal 50 degrees celcius
i dont know what to do...
what speccy says
Motherboard
Manufacturer XFX
Model XFX nForce 790i Ultra 3-Way SLI (Socket 775)
Version 1
Chipset Vendor NVIDIA
Chipset Model nForce 790i Ultra SLI SPP
Chipset Revision B1
Southbridge Vendor NVIDIA
Southbridge Model nForce 790i Ultra SLI MCP
Southbridge Revision A3
System Temperature 86 °C
BIOS
Brand Phoenix Technologies, LTD
Version 6.00 PG
Date 9/10/2008
Voltage
CPU CORE 1.136 V
MEMORY CONTROLLER 1.368 V
+5V 4.872 V
+3.3V 3.248 V
CPU FSB 1.320 V
VIN2 0.144 V
DRAM 1.832 V
PCI Data
Slot PCI
Slot Type PCI
Slot Usage Available
Bus Width 32 bit
Slot Designation PCI0
Slot Number 0
Slot PCI
Slot Type PCI
Slot Usage In Use
Bus Width 32 bit
Slot Designation PCI1
Slot Number 1
ok so first before buying any ram you must check the mother board ram memory specs "the mother board lists memory types brands how many sticks and how much gigs in each stick it will handle. here is the 790i list
http://www.nvidia.com/object/product_nforce_790i_ultra_...
with in there you choose """Memory Compatibility List (1.56MB PDF)""""
here is the link
http://www.nvidia.com/content/nforce700i/nForce_Intel_M...
this tells you exactly what memory it can use and how many sticks of how many gigs and what brand, other than that,, alot of time is going to be spent in the timings and so on..
i my self found this out with my 790i bought 8 gigs of ram, they didnt meet the requirements, the meet the standard 667hz, 8 gigs, some other stuff power volatge and what not,, a while ago soo i put my 4 gigs back in the mobo and am going to buy some ram that matches the compatibility list
