Nfs the run problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
hey friends..
I have Installed my game correctly but when i m trying to lauch it from Need for speed the run.exe then A Black screen Appears and A Picture flickering appears...
then wat pictures remain Flicker and Nothing comes up in spite of Successfully Installing the game....
i was 2 gb RAM,512 GB HARD DISK,1 GB GRAPHIC CARD
AND WINDOWS 7 OPERATING SYSTEM...
BHAIYO IS PROBLEM SE DIMAAG KHARAB HO GAYA HAI
AGAR IF ANY ONE HAVE THE SOLUTION OF MY PROBL
EM SO PLZ TELL ME ?
Yes..friend i have downloaded Need for speed The Run Limited Edition
May be it is pirated dear....
I have installed the game and when i m trying to open .exe file with Origin
Then Game starts and A Black screen appears and only A Picture is flickering on the black screen...and it goes on continuosly nothing happened after pressing the keyss...
U knw I have downloaded NFS THE RUN Two times
firstly i downloaded NFS THE RUN BLACK BOX Which also has created the same problem (black screen and picture flickering on it n goes continously)
So i deleted dat game because i thought that may be the fault in the setup of the game of nfs the run black box
But
After that i downloaded NEED FOR SPEED THE RUN LIMITED EDITION
Then also it creating the same problem...
I have installed 296.10-desktop-win7-winvista-64bit-english-whql VERSION OF NVIDIA Driver then also it creating problem..
I think this is some kind of graphic problem or directx problem
but i am not able to encountering the problem
So,I m helpless Can you plzzz try to solve myy problem?
Can You help me ?
First of all,
Don't type words in capital letters. It implies that you're shouting.
Secondly,
No other language apart from English is to be used here, so that we can help solve your problem.
Last of all,
Tomshardware does not promote piracy, and we will not help other members to help you run/crack an illegally downloaded game. It's against the rules.
hey friends..
EM SO PLZ TELL ME ?
:hello: google it by typing NFS RUN BLACKBOX FIX..................i hope it will help u.... 😀
