Question NH-D15 Fan Control Help
christonian
98
I ended up ordering the NH-D15 when my H100 v2 failed on me this past weekend
What software do you use to control the fan curve?
I used to use iCue from Corsair but I cant control anything from that
Do you let it run at 100% or do you have a fan program and on a fan curve
i4790
Z97 Killer
christonian
98
Well i do approve of a new fan but is the fan system Bios controlled or do you have a fan controller? I just need more info.
Just plugged directly into motherboard so I would assume BIOS but was hoping for 3rd party fan software?
Under Bios there are a few options like silent, standard, performance etc but was hoping to control from Windows if possible
The NH-D15 fans are very quiet and you will have no problem letting them run at full speed.
I find a constant sound to be less annoying than a constantly changing fan.
The NH-D15 will also come with low noise adapters if you want even quieter operation.
Yes, the fans can be controlled by the motherboard bios options, but I would not bother.
Try running full out before you invest in something you may not need.
Reactions: falcon291
christonian
98
Thanks just was hoping to be a bit quite I think it is slightly louder then my H100v2 but now it is running as it seems 100% no speed up when under load for example, same fan speeds when idle vs gaming and streaming which is 50+% load for my CPU
