spiers333 Reputable Jan 23, 2015 310 0 4,780 Feb 22, 2015 #1 Hi im looking for some nice case fans that i can mount as top mount and front intake
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Feb 22, 2015 #2 Corsair AF. Upvote 0 Downvote
Darkbreeze Retired Mod Jun 24, 2014 82,635 8,306 176,790 Feb 22, 2015 #3 What size fans do the locations you are looking to fill accommodate? 120mm, 140mm, 200mm, ?????? Upvote 0 Downvote
spiers333 Reputable Jan 23, 2015 310 0 4,780 Feb 22, 2015 #4 Darkbreeze : What size fans do the locations you are looking to fill accommodate? 120mm, 140mm, 200mm, ?????? 120 Upvote 0 Downvote
Darkbreeze Retired Mod Jun 24, 2014 82,635 8,306 176,790 Feb 23, 2015 #5 What is the model of your case and are they for case fans, exhaust on top, intake in front, or is there a radiator somewhere? If they're just going to be standard case fans, I'd recommend these for exhaust: http://www.noctua.at/main.php?show=productview&products_id=91&lng=en&set=1 And these for intake: http://www.noctua.at/main.php?show=productview&products_id=42&lng=en&set=1 Upvote 0 Downvote
