Nikon Coolpix P900 zoom motor makes strange sounds
foobar3001
Hello!
I have a Nikon Coolpix P900, which seems to work really well. However, the zoom motor makes strange sounds.
As you can expected, it takes a few seconds to zoom out or in fully. During those few seconds, the smooth whirring of the motor is interrupted about once a second by a sort of 'clunk' sound, which I can also feel as a brief thud in the camera body.
Has anyone else experienced this? Is that normal for the P900? Or should the zoom motor run completely smoothly?
Any feedback would be much appreciated.
Thank you!
foobar3001
Thank you for your reply!
Yes, it does make the same sounds, even then.
