Nikon + Photoshop RAW problem!
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: rec.photo.digital.slr-systems (More info?)
I can not figure how to solve this stupid problem that
has occurred here 🙁 The problem is when I want to
open RAW file (.nef) I get some small gray window
with only white balance options to correct instead the
adobe camera raw dialog window with all the great
options that I need?
I have PictureProject installed but I work in Photoshop
or I did until this problem has occurred.
Thanks for help,
Tom
You need to remove the Nikon NEF plugin, it takes precedence over the Adobe
one.
John Bean
Computers can figure out all kinds of problems, except the things in the
world that just don't add up (James Magary)
You've just installed the Nikon Capture software and it's put a horrid
little file in your Photoshop plugins directory.
Here's the path to investigate:
Program Files\Adobe\Photoshop CS\Plug-Ins\Adobe Photoshop Only\File
Formats
I think the file was is called Nikon.8bi - something like that. Find
it and move it out of that directory (there is an 'Old Plugins' you
can put it into). Restart PS, and everything should be as it was
again.
Owamanga!
http://www.pbase.com/owamanga
Uninstall Nikon Capture. Then make sure you download the RAW plugin
enhancement version 2.4 from Adobe's site.
Thomas T. Veldhouse
Key Fingerprint: 2DB9 813F F510 82C2 E1AE 34D0 D69D 1EDC D5EC AED1
Spammers please contact me at renegade@veldy.net.
"John Bean" <waterfoot@gmail.com> wrote in message
news:1iaygb0eyoyuv.dlg@waterfoot.net...
> Adobe
> one.
Where do I find it?
(James Magary)
"Owamanga" <owamanga(not-this-bit)@hotmail.com> wrote in message
news:5kuq511o2rlrqmcpqg64d8836uctmtkg56@4ax.com...
> Formats
> again.
YES ! Thanks that was it :) :)
Thanks a lot,
Tom
uninstalling doesn't work.....
"Thomas T. Veldhouse" <veldy71@yahoo.com> wrote in message
news:425d7f8d$0$32865$8046368a@newsreader.iphouse.net...
> Thomas T. Veldhouse
