Nimi Places Help, Small Icons
Nallan
54
Hello
I was wondering if there is anyway to make the icons on Nimi Places bigger.
They are set to max size currently, but some shortcut pictures are still very small, while others are large. Everything else in in between.
I would appreciate some help.
Thanks, A
Hello,
To change icon size ​in containers supporting this feature, try the following:
- Press Ctrl+"+"/"-" key combination either to zoom in or out.
- Hold Ctrl key while rolling mouse wheel to adjust zoom.
- Open container settings, open View sub-menu and select icon size from the list.
Hello,
Hi,
Have you tried to change the icon size with the instructions provided above? Since I currently do not use Nimi Place, hard to tell for me what is going on exactly on your desktop.
You may want to have a look this Youtube tutorial for your application, currently has 2 parts.
[video="https://www.youtube.com/watch?v=YkiqLpy9fOo"][/video]
