Hi,
suddenly on both of my Operating systems on the same PC there is no sound anymore (nothing at all). I figured the problem cannot be the driver or any windows setting since it's the same on both windows installations and one of them I havent used for a while, so that they are in a different stage. HAs worked fine on both before.
I havent changed anything in the meantime, not hardware nor software. The speakers work fine. Once I plug them to my laptop, no problem. And yes they are plugged in correctly. Even plugging them to the other ports doesnt change anything.
SO I am suspecting that there must be a hardware failure. But I am really wondering if that's possible that only the sound stops working while everything else works fine.
Before I buy a new mainboard or soundcard I would like to ask you guys about your opinion. What else could cause this? If the audio chip is defective, buying a sound card should function, am I right?
Thanks for advice.
Regards
Phil
Thanks for advice.
Regards
Phil
