No audio .mp4 - please help
thepregnantgod
261
I have some great home movies my boys made while playing with the webcam.
I specifically remember there being audio attached but now, a few years later, there is no audio whenever I play it.
I've used all the Windows programs to play it.
I've download VLC and attempted to play it.
I've installed Quicktime - still no audio.
Media Info reports this:
General
Complete name : D:\Movies\WIN_20131220_171744.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/isom)
File size : 36.3 MiB
Duration : 43s 260ms
Overall bit rate : 7 041 Kbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Source duration : 43s 277ms
Bit rate : 7 025 Kbps
Width : 1 024 pixels
Height : 768 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 29.577 fps
Minimum frame rate : 1.745 fps
Maximum frame rate : 31.480 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.302
Stream size : 36.2 MiB (100%)
Source stream size : 36.3 MiB (100%)
mdhd_Duration : 43245
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Source duration : 43s 261ms
Bit rate mode : Constant
Bit rate : 1 378 bps
Nominal bit rate : 192 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Frame rate : 43.066 fps (1024 spf)
Compression mode : Lossy
Stream size : 7.28 KiB (0%)
Source stream size : 7.28 KiB (0%)
mdhd_Duration : 43260
rmarier83
108
Do other videos play with audio on your computer? If they do, try downloading K-Lite codec pack (mega version), install it default everything. I also noticed that your audio is mono (1 channel) that is also sometimes a problem, you could try mixing that into 2 channels.
thepregnantgod
261
Other videos do play with sound. I did install the K-Lite codec pack...no go.
So, if media info says there's sound shouldn't I at least be able to extract it or anything to test that it's there?
