No Audio Output Device Installed
MKWOODARD
6
Hello ALL
PLS PLS PLS TELL ME SOMEONE CAN HELP-
I have a HP2000 Notebook-
left on other night-when i woke im not sure what had happen,but i couldnt watch movies and my sound was missing-I have for 2 days now uninstalled and reinstalled diff drivers-media player still doesnt work-sound says NO AUDIO OUTPUT DEVICE INSTALLED-I can get netflix to play now but with no sound.I have tried multiple things turning on/off thw windows audio endpoint builder-all 3 those in that area are set automatic and running-when i look in my sounds through control panal it shows a check mark on the Realtek(says working perfectly)Have ran Driver Booster multiple times NOTHING-says all is updated-im so lost on what to do next-ANY HELP IS VERY MUCH APPRECIATED!
Win 7 premium home on an Acer Aspire.
Error when starting Windows Audio Service: Error 1068: The dependency service or group failed to start
Method 2:
Check the services manually.
I suggest that you check if the dependency services are started and check if you have the same issue.
a. Click Start, type Services.msc in the Start Search box.
b. Scroll down the list of services, right-click Windows Audio and select Start.
c. Select Properties for Windows Audio and set its Startup Type to Automatic.
If the Windows Audio service does not start and you get the error ‘Error 1068: The dependency service or group failed to start, then make sure that the following services are started and their Startup Type is set to Automatic’...
Ive done that to no avail-i have gone to website to see if updated drivers are avil and says have the latest
I have ran my windows update-says i have the latest-i have uninstalled and restarted many times in last 2 days-im jus not sure what tha heck-grrrrr!ty for tryna help btw-
i was previously running a windows 7 and upgraded few mos bck to 8.1-
»HP 2000-299WM Notebook PC
Serial Number: 5CB1516Z40
Product Number: QE282UA
i have been to hp website and microsofts walking away jus as flustered as wen i went there-
thanks for ya help-
Method 2:
a. Plug and Play
b. Multimedia Class Scheduler <-- in my case this was disabled
c. Windows Audio Endpoint Builder
http://answers.microsoft.com/en-us/windows/forum/windows_7-pictures/no-sound-error-1068-dependency-service-failed-to/be5cc914-54b1-4aaf-83a4-43e8b5d31c65
on another forum they also had people double check the power service was enabled and started.
