M mrmgf Distinguished Mar 3, 2011 5 0 18,510 Mar 4, 2011 #1 Hello, is the only answer is to get a usb sound card ?
Solution tecmo34 Mar 7, 2011 Here are some options... http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=usb%20sound%20card%20for%20laptop&IsRelated=1&cm_sp=KeywordRelated-_-usb_sound_card-_-usb%20sound%20card%20for%20laptop
tecmo34 Administrator Moderator Jan 20, 2009 9,337 122 37,590 Mar 4, 2011 #2 Have you install the motherboard onboard sound drivers? What is your motherboard make and model? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,755 1,835 159,590 Mar 4, 2011 #3 i agree you just need the right driver! Upvote 0 Downvote
M mrmgf Distinguished Mar 3, 2011 5 0 18,510 Mar 4, 2011 #4 the computer is an hp 9710 and it has a quanta motherboard, i think the sound card which is intergrated is bad, can't install a driver if the os can't find a device and i am running win 7 Upvote 0 Downvote
W w7pro Distinguished Dec 30, 2010 181 0 18,710 Mar 4, 2011 #5 Have you tried to run the MS sound diagnostics to try and get a more definitive answer to what the problem may be? http://windows.microsoft.com/en-us/windows/help/no-sound-in-windows -- Ryan Windows Outreach Team Upvote 0 Downvote
M mrmgf Distinguished Mar 3, 2011 5 0 18,510 Mar 7, 2011 #6 w7pro : Have you tried to run the MS sound diagnostics to try and get a more definitive answer to what the problem may be? http://windows.microsoft.com/en-us/windows/help/no-sound-in-windows -- Ryan Windows Outreach Team yes i have tried all of that how much does it cost to get a new sound processor soldered in or can i purchas e a usb sound card ? Upvote 0 Downvote
tecmo34 Administrator Moderator Jan 20, 2009 9,337 122 37,590 Mar 7, 2011 #7 You can get a PCI sound card for about $30 depending on if you have the open slot on the motherboard or not. Upvote 0 Downvote
M mrmgf Distinguished Mar 3, 2011 5 0 18,510 Mar 7, 2011 #8 hello, i have a notebook computer Upvote 0 Downvote
tecmo34 Administrator Moderator Jan 20, 2009 9,337 122 37,590 Mar 7, 2011 #9 :lol: My bad 😀 Upvote 0 Downvote
tecmo34 Administrator Moderator Jan 20, 2009 9,337 122 37,590 Mar 7, 2011 Solution #10 Here are some options... http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=usb%20sound%20card%20for%20laptop&IsRelated=1&cm_sp=KeywordRelated-_-usb_sound_card-_-usb%20sound%20card%20for%20laptop Upvote 0 Downvote Solution
M mrmgf Distinguished Mar 3, 2011 5 0 18,510 Mar 14, 2011 #11 Best answer selected by mrmgf. Upvote 0 Downvote
