Hey guys, been working on this the last two days.
I have been working on recovering data from my SSD on a different computer, and since I had the case open to put it back, I decided I'd reapply the thermal paste on my processor/heatsink (CoolerMaster hyper 212+).
Once I plugged everything in and hit the power button, that's when I noticed that it wasn't working right.
All the fans were powered (including the video card), the motherboard was powered (the LED's were green), and I'm pretty sure (but not positive) that my harddrive and SSD were powered.
Everything was going well, except the monitor showed an amber light (no active signal from the current connection) from either video card, the motherboard with the video card attached, nor the motherboard's output without the video card attached.
When I was prowling these forums, I noticed that people said to check each memory stick. I removed each one at a time, and had the same issue.
I also noticed that people said it's a power issue. So, I decided to swap out power supplies with an old antec 500W that I used to use, and that didn't work either (same exact symptoms as described above).
Last time this happened, it was because I bent a few pins on my processor. So, I removed the processor, and checked that too, to see that there were no bent pins (there weren't any), and I'm pretty sure it's all set correctly.
I tried it without the corrupt SSD attached, and that didn't work either. Also, when I remove the VGA cord from the computer, the monitor shows "no signal" and those color bars you see on TV, so the monitor works fine.
Any idea what's wrong, or what I can do to keep testing it? The coolermaster heat sink has a backplate which, if what I read about it is correct, is supposed to prevent the motherboard from bending, and it shouldn't be bending.
I saw some people posting about the case shorting out the power, so I tried putting tape between the screws protruding from the backplate and the metal casing, but that didn't work either. Not sure what else I can do for this.
I'm almost positive there's no DMM in the house, so if possible (and the troubleshooting isn't too ridiculous without one), I'd appreciate it if any ideas to fix this don't include one since I'm a bit broke (college has a tendency to do that
), but if it's the only way I can find out how to fix this, then it won't kill me to buy one.
Thanks for the help, I appreciate you guys reading this. Hopefully this goes quick. Here are my specs:
AMD Phenom II x6 @ 3.7Ghz (OC)
CoolerMaster Hyper 212+ Heat Sink + Fan
ASUS M5A88-V EVO
Radeon HD 6950 1GB
A standard disc tray..
WD 750GB HDD (Sata III)
Corsair Force 3 GT SSD 90 GB (Sata III)
G.Skill 8GB (6 ATM, removed one and haven't put it back) 1333 Mhz DDR3 RAM
Windows 7 Ultimate
Antec Earthwatts 650W PSU (80 plus bronze) --- I really need something modular >.>
UPDATE::::
Popping the Motherboard battery out, hitting the power button twenty times or so, then putting it back in worked perfectly. I owe my friend a few drinks for helping me, thanks to all who responded.
ASUS M5A88-V EVO
Radeon HD 6950 1GB
Windows 7 Ultimate
UPDATE::::
