no bloody sound
7
hi there i have hooked my zoostorm up to my 32" TV using a dvi connector with a hdmi lead from it to TV as there is no VGA port on the tv, I have also connected a audio lead from comp to the audio ports on the tv but i still have no sound, i've been into the device manger and the sound is playing but not out the tv. can emdy help me out here please?
hi USAFRet i have went into the settings on tv n selected hdmi and also went into the audio settings but nothing
What model is the TV? I want to google it and get a image of the back panel.
DVI doesn't carry sound, but HDMI does. So the TV might want sound from that input and you plugging in left & right RCA's for sound, might be on a different TV input?
Yes, I looked at the back panel. And I assume you've had no luck?
As you have 2 HDMI inputs and a component input [your 3 colors and 2 audio(L+R)]
So plugging audio into the component and using an HDMI input for video, won't work.
A DVI to component "cheater cable" would be the easiest.
http://clubfiles.liba.com/2006/05/20/14/3512051.jpg
Ideally you would get a video card with an HDMI output. Most GPU's now have: display port plus HDMI and DVI.
http://www.legitreviews.com/images/reviews/1854/7770-dvi.jpg
