No built in WiFi on my motherboard!
Nov 14, 2018
Hi guys, I have purchased a motherboard that doesn't have built in WiFi. How will I be able to solve this problem? I would prefer an ethernet connection but I'm not sure what I'd need in preparation.
That is the problem. The "chicklet" sized adapters are too small to have a decent sized antenna built-into them. There performance is usually subpar compared to an adapter that has a standard sized stick antenna.
All you need is a Cat5e ethernet cable from your PC to the router.
Your motherboard has an ethernet port.
How long is a piece of string?
How long a cable is up to you to determine. However long you think it is, add 30%.
