"no cable connected" tried everything - new graphics card, cables and monitor
Jul 31, 2018
4
1 week ago my pc went black when I turned it on. It says "no cable connected". Ive tried another HDMI cable and another DVI cable. So its not the cables. Ive tried another monitor, that didn't work either, so its not the monitor. Today I got my self a new GTX 1060 6 GB. I installed it to my pc and booted up. The pc worked fine! Then after 5 minutes my pc froze so I turned it off and on again. When it got back on it said "no cable connected" again just like in the start. HOW THE F***?.
And yes I have the DVI connected to the graphics card;)
Really frustrated at this point, and dont know what to do....
Cheers!
terry4536
Glorious
Herald
Another possibility is that the RAM needs to be reseated. The first indication of this is no video out.
Remove each stick of RAM one at a time clean the contacts, blow out the slot, firmly reinstall (make sure that levers on the slot are all of the way up), and repeat for remaining RAM.
Jul 31, 2018
4
This didn't work either..
Jul 31, 2018
4
Well only thing remaining then is buying a new PSU, I will give you feedback when it gets here.
clutchc
Herald
It is helpful if you list your system components when seeking help. Is this a pre-built PC or one you built? What is the make/model of the PSU you have now?
