Question No Display after replacing Thermal Pads ?
Jul 18, 2023
So I've had some issues before with my Rx 580. After it hits 65°C it throttles and clocks itself down to 600mhz. So I thought of replacing my thermal pads. I've done it carefully and when I reseated it into my motherboard I would not get any display while booting then it showed me the windows 11 login screen for a split second and then there was again no display. Would appreciate if any one would be able to help me.
PC specs:
Ryzen 5 2600x
12gb DDR4
Corsair VS650
ASRock b450 steel legend
Rx 580 8GB
( I am sorry if there are any grammar mistakes or something like that I am not a native English speaker )
check your assembly again, maybe the screws are to tight o you forgot something to connect
unplug and replug the GPU to the motherboard
power connector connected to the GPU?
hardware fault
might be the GPU´s or RAM´s soldering cracked on the board ->resolder with heat gun
hardware fault
It's most likely a hardware-related issue since I've tried almost everything. I could try to resolder the gpu with a heat gun if I have one at home
Corsair VS650
How old is the PSU in your build?
Was the GPU bought brand new or used?
I don't know how old the PSU is since I bought it used but I replaced everything besides the PSU and the case. It's the VS650 with the Orange text. And the GPU was also used. I can't afford any new parts right now and everything I've got in my PC is from a friend.
PC specs:
Ryzen 5 2600x
12gb DDR4
Corsair VS650
Rx 580 8GB
If you are facing this issue you just need to check connections, verify monitor connections, reset BIOS, test in another system, update drivers, try integrated graphics, and check for physical damage.
