The system has power but the benq monitor is telling me there is "no signal detected " normally if it's a cable issue the monitor will say " no cable connected.
I have done all the obvious checks on cables swapped out the HDMI cable for new one
Tried removing the GPU and running the onboard Intel graphics
Still the same "no display detected"
I can see fans running on the GPU and CPU
However I use a backlit keyboard and it does not light up which makes me wonder if I actually have a boot problem rather than a display problem
I'm running Windows 10 on a Samsung SDD
HDD separate
GPU is nvidia GTX 1080
Asus motherboard
It a pretty new machine less than a month old
I'm wondering if the SDD has failed any comments welcome
Also if it is the SDD that has failed Is it possible to remove an old HDD from a machine and put it into this machine to see if Windows 7 will load
HDD separate
Asus motherboard
