I have a Custom build PC from 2013
Asus A55M-A Mobo
AMD Richland A-10 6800k CPU
2x Kingston hyper X beast 4GB ram
Gfx Radeon R9280x card
PSU Aurum 92 series PT 550M
NZXT tower case
Nocturna dual fans
1 TB HD
One day the screen started going green then the PC turned of and it wouldn't turn on.
After resetting it and mucking around a bit I got it to turn on but it had no display signal when turned back on.
After unplugging the gfx card it will display after using the integrated gfx via DVI
I cant get it to run of the gfx card at all.
Gfx card has power on both external 6pt vga points and the fans are spinning.
Things I have done so far include:
Uninstalling the drivers
Rolling back the drivers to 2016 Crimson
Installing latest drivers again
Manually installing windows update
Cleaning the whole PC- but not inside the pci slot, yet...
Using compressed air to clean the whole PC including the gfx card as well as manually cleaning the gfx card points.
Resetting CMOS battery
Checked bios is running pci first and integrated last.
Made sure all the wires to the mobo and gfx card are secure.
Checked Power and Ram are fine in both both bios and windows and no conflicts.
Atm it's working via integrated and I haven't reinstalled drivers as they were completely wiped via utility and gfx card isn't in devices.
I haven't cleaned the pci slot
I haven't unplugged the ram to clean (but bios and windows say there fine)
I haven't rewird everything
I dont have a friends PC to check the gfx card
Any thoughts or help would be appreciated.
Asus A55M-A Mobo
NZXT tower case
Nocturna dual fans
1 TB HD
