I'm currently in the process of building my first computer and I decided to build outside the case to ensure everything works. I plug everything into the right place. Put in CPU (amd), put stock cpu cooler and plug it in. 24 pin plug from power supply, 8 pin cpu power, ram modules (2x4gb) and GPU and I put two pci express cables into it. I'm pretty noob at this but I'm pretty sure i did everything right. I plug in my hdmi (that defintley works) into the GPU and other end into my monitor. EVERYTHING is working, well atleast i think it is. I can hear everything, and all the fans are spinning even the GPU fans are spiinning. The problem is that there is NO DISPLAY. What are some things I can do to get display, or figure out what is wrong?
HELP! Thankyou.
P.S
Here's my build if it will be helpful to recognize my problem. http://pcpartpicker.com/p/BzDQ99
HELP! Thankyou.
P.S
