Question No display input and white VGA light on ?
May 16, 2022
I was getting a white vga light and no input on the monitor yesterday, shuffled components around and tried to reconnect everything but the problem persisted even when attempting to use integrated graphics. I moved the components over to the old motherboard and the repeated the process but the problem was still persisting. Does this mean I’ve got a problem with my CPU or could it be something else?
Ryzen 7 5800x
Rog strix X570i mini itx
MSI ventus 3x 3080
Phanteks Revolt 750w sfx
Corsair vengeance RGB pro 2x16gb 3200mhz
boju
Ambassador
Was this system working before or is this a new build? If this is a new build you'll probably need to update bios with help from a computer shop whom would have previous generation cpu compatible with your board out of the box.
If this system was working previously, try borrow another gpu for testing.
Rear video ports is for cpu's with igpu, ie 5600g.
